If you are going through a lot of "convert > burn > view on DVD player > tweak > repeat" cycles, consider burning to a CD-RW instead of a CD-R. I'm not sure of the compatibililty in all DVD players, but a VCD burned to a CD-RW plays just fine on my Sony DAV-500. When I want to make changes, I just erase and re-burn!
The only down side to this tip is that RW speeds tend to be slower. My CD-writer burns at a quick 16X with CD-R, but only 4X with CD-RW. So, you will have to weight your time against the cost of inexpensive CD-Rs.
An additional tip: just encode a short (1-2 minute) clip of a high-action scene to check your encoding results - this works for me, and I don't have to wait for my burner to burn an entire disc......
I picked up some Pocket-CDRWs. They are for lack of a better word, sexy!
Very cool, 24 minutes and very small, reuseable.
I burn a lot of stuff to cdrws to see how it comes out first. It's almost impossible for me to get a decent capture most of the time =/
Freemake Video Downloader: A Tip or Two
By Tom Saurus in forum Video Streaming DownloadingReplies: 0Last Post: 7th Feb 2012, 22:45 -
Software tip
By emayd in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2010, 16:44 -
Tip To Rip DVD To MKV
By dgarcia11087 in forum DVD RippingReplies: 4Last Post: 17th Mar 2010, 03:29 -
tip... How to rip a partly-damaged movie DVD
By JohnnyBob in forum DVD RippingReplies: 7Last Post: 23rd Oct 2009, 14:00 -
iPod Performance Tip!!
By GMaq in forum Portable VideoReplies: 2Last Post: 21st May 2007, 08:40
