Hy guys,
I need to convert an AVI movie because it's to big for a cd.I try to use Virtual Dub but I can openn my file.
Then I try to cionvert with TMPGEnc but when I try to open my AVI file(the source file) the program show me this message: "name of my file.avi" can not open or unsupported.
If I try to open with TMPGEnc the original file(mpeg) it let me to open...how can I convert my file?
I make it with Adobe Premiere, and I export it in AVI format...
Teo
slow down and start over your not making sense
Try this guide http://www.vcdhelp.com/divxtovcd.htm
I'll try to help
are you trying to cut this to put it on 2 cd-r'sI need to convert an AVI movie because it's to big for a cd.I try to use Virtual Dub but I can openn my file
.Then I try to cionvert with TMPGEnc but when I try to open my AVI file(the source file) the program show me this message: "name of my file.avi" can not open or unsupported
read this read the first paragraph
http://www.vcdhelp.com/tmpgenc.htm#problems
Why are you trying to convert if its already mpgIf I try to open with TMPGEnc the original file(mpeg) it let me to open...how can I convert my file?
Good luck
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Thank you..now I try to see the guide you said.
I don't cut because the video is long only 4 minutes...
I said "if I try to convert the original video(Mpeg)" only for say the TMPGEnc don't let me to work on AVI video but it let me WITH a Mpeg video... -
Remember that AVI alone doesn't mean much. Important is the codec which is used for the AVI (divx, mjpg, huff,...)
It's the firt time I worked with video..and i'm learnning alone.
I record a video with my camera and I import it on computer thanks to a friend. Then I used Adobe Premiere for cut and put music and transitions beeetween the scenes. To see my work I export the project with Aobe Premiere in AVI but I don't know yhe codec...but I really need to put my video on a cd,it's only 4 minutes and I can' believe I can't convert in a smallest format.
May be my problem is the codec because I use Virtual Dub and TMPGEnc but I can' worked on muy file.
How can I see the codec of my Video?
Thanks a lot
TEO
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
