i use smartripper to rip the dvd to vob files...then when i try to load the ifo into flaskmpeg it dosnt see the ifo...only sees the vob's which means it will only convert 1 segment of the dvd at a time.it seems the version i used to have would see the ifo file and convert with no prob.any ideas????
thank you
Ted
If I remember correctly Smartripper is not that smart because you have to manually tick the IFO box before you rip the DVD. DVDdecrypter will do this automatically.
thank you for your response but the ifo file is there...just when i try to load it in the flaskmpeg it dosnt see it...just sees the vob's...if i right click on the folder where i put the vob's the ifo is in there.
use smartripper file mode to extract the vobs. movie mode is default
I had exactly the same problem (From File - Open media 'DVD MISM (*.ifo
' was not listed as a supported file type). I've solved it by downloading Flaskmpeg again and re-installing.
You need to install another component that tells Flask how to parse
IFO files. The zip file is "thunder.mism.zip"-- get it where you
downloaded Flask from.
Just extract it and move it into the directory where Flask is installed.
Missing VOB
By 5ZVP in forum DVD RippingReplies: 5Last Post: 20th Jul 2011, 21:03 -
Missing Codec?
By jimbb in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2011, 14:54 -
Letters are missing...
By alintatoc in forum ComputerReplies: 9Last Post: 5th Jul 2009, 08:35 -
Missing ifo
By Kurgan71 in forum SubtitleReplies: 1Last Post: 16th Jun 2009, 01:24 -
missing sound
By agent222 in forum Video ConversionReplies: 6Last Post: 27th Mar 2009, 09:51
