i have used Dvdx loads of times without any problems, now when i use it i set up my input settings and then get this message "auth.dll Can't authenticate drive, Disk may not be locked ".
then when i encode the dvd it only does about 24% of it and then freezes with the same message as above appearing, please help, iv'e uninstalled Dvdx and re-installed it but the problem remains, any help would be appreciated
Hi markpro
try updating your aspi drivers or look to see if your auth.dll file is in the dvdx folder if not put it there from the zip file u av from dvdx, i think?
hi,
i too get the error but i tried all things i can think of nothing helps. Some time it does not give the error but mostly does. just say ok and proceed. no harm is done every thing works like a Charm.
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 18:58 -
1920x1080 / 59.94i Footage From High-Def Camcorder - TMPGENC Auth. Works 4
By bmccollum in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Oct 2010, 12:31 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 14:34 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 18:28 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
