I'm in a process to buy a new PC mainly use will be converting avi to mpg then burn (either as is or to vcd). Current PII 300 is too sloooooow. Is a 1.6 GHZ fast enough to do the work or do I need to go with higher? I just want to spend the min and reuse my burner and monitor. Any suggestions?![]()
Results 1 to 9 of 9
Go to NewEgg.com and order a 1.6AGHz P4, MSI 645E MAX-C motherboard and a stick of Samsung PC-2700 DDRAM. For $297 I know have a 2.4GHz system(the fsb is overclocked to 150mhz)thats very very stable and fast.
Dont go for the top of the range there is always a huge premium to be paid for the kudos of having the fastest chip. For example CCL computers sells the AMD athlon XP2100+ for £203.83 and the XP1900+ is only £115.29. I bought the XP1900+ and found I could easily overclock it to the speed of the XP2100+, I could even get it to register as an XP2200+ which is'nt even available yet.
Craig -
Craig is right they will charge you alot more forthe newest try a amd 1.7 they are fairly cheap right now and its equal to about a p4 2.0.
This is proboly a ice cream induced thought so i can not take no control for the above statment. :P -
yea go for an AMD they are cheaper and faster then a pentium..i sugest a AMD Athlon XP +1700
also u may want to go with a dual processor.....cuts your time in 1/2. but remember not all apps can use a 2 processors. tmgenc is what i do most of my divx converts in and it does. also u need win2k-xp, 95-me won't support dual proc.
As indicated in this benchmark of TMPGEnc, it may improve the performance by 1/3 or 33%:
http://hardocp.com/article.html?art=MjU3LDQ=
Hope this helps.
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
Is it my processor?
By davej1983 in forum Software PlayingReplies: 7Last Post: 11th Jan 2009, 01:53 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
Processor
By Tom in HD in forum MacReplies: 1Last Post: 1st Dec 2007, 22:02
