Does anyone know how to use Mpeg repair 1.58 to patch the pan and scan info of a mpeg file?
I've been using guides to put svcd onto dvd-r. The only problem I consistently have is the picture is never quite centered right.
I have a Pioneer 333 dvd player. I've read in other posts that you can use mpeg repair 1.58 to patch the pan and scan info on the mpeg to fix the prob. but I've not been able to find any instructions on how to do so.
Any help would be great!!
encoding > parameters > MPEG-2 options parameters
I don't think, that MPEG Repair give you the option to patch an existing MPEG-2, as far as I understand that, it is only an encoder option.
Pot Player no pan scan ?
By nic3 in forum Software PlayingReplies: 0Last Post: 26th Apr 2011, 03:10 -
pan and scan vs keep aspect ratio
By tommcd64 in forum Video ConversionReplies: 1Last Post: 13th May 2009, 14:05 -
What is Pan and Scan?
By janlafata in forum Newbie / General discussionsReplies: 7Last Post: 15th Jan 2009, 21:27 -
Letterbox/Pan-Scan - Encoding or authoring option?
By ecc in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2007, 01:40 -
Pan & Scan a video file for iPod?
By acid_burn in forum Video ConversionReplies: 6Last Post: 5th Jun 2007, 23:58
