Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Feb 2001
    Macondo, Puerto Rico
    Hi All,
    What dows "General use" means in the description of the DVD writing capabilities of the Pioneer DVD-RW Drives?
    Regards,
    Jose
    Dec 2001
    Wisconsin
    I use the general use DVDs from meritline $1.30 apiece and have no problems with Video or data put on these, I have sent DVDs to many people and they are VERY compatable.
    May 2001
    "General Use" DVD-Rs are the standard, everyday recordable media. The other catagory is "Authoring Use" DVD-Rs, which (as you might suspect) are used primarily for authoring a DVD. The two are not interchangeable, because each requires a different laser wavelength to burn.
