Hie,
I have put a few video track on a cdr>
and playng back on a vcd player.
first track playng verry well but always the second track is not good at all.but are playing verry well on the pc.I have inversed the track on the cd the same think again always is the second track?
Can any one help please.
1) make sure you burn no faster than 4x
2) which proggie are u using to make VCDs? try to use nero....i'll also assume you're making it standard compliant vcd 2.0 cuz you're playing it on a vcd player (if not, it could be the bitrate is too high for your vcd player to handle)
3) could be the vcd player not able to handle the cd-r you have (cheap, weak laser????) try another brand and c if it works...or test it on a friend's dvd player
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 19:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 05:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 12:20
