---I keep trying to convert avis to mpegs using tmpegnc but the stall. Why?
I don't know your exact situation, but this happened on me once with an AVI (divx) file I downloaded off Kazaa. After much trial and error, I finally determined what I think caused it. Kazaa didn't get the whole file in one session, it got part, then later resumed and got more, then later resumed more etc. When I tried to convert this file, it was stopping at the same point that Kazaa had stopped/resumed at, so my guess is some frames were getting corrupted when it does a resume. I verified this by re-downloading the same file in one session, and this time it converted fine. It may not happen every time, and again this may not be what happened with your source, I'm just sharing what happened to me.
I am affraid that you are probably right. Thats what I thought. What a waste of time downloading all that time. Thanks.
Download virtualdub 1.10 (tools, left of page). Open your avi file with virtualdub and select video->scan stream for errors. Once complete, still in vdub, select auid-direct stream copy, video->direct stream copy, file->save avi and output a new copy of the avi with the corrupt frames removed. You will now have an avi file that will encode properly in TmpGenc. However, if the number of bad frames was large you may experience audio sync problems in the latter part of the file.
How to stop Explorer from locking video files?
By Djard in forum Newbie / General discussionsReplies: 25Last Post: 14th May 2011, 02:24 -
How do you stop Explorer from locking video files?
By Djard in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2011, 01:49 -
How do I make Mencoder stop converting 3 - 10 files at once?
By gemasis in forum Video ConversionReplies: 3Last Post: 29th Dec 2008, 15:56 -
Youtube .flv files quickly stop playing but will play past half way point
By video1312 in forum Software PlayingReplies: 1Last Post: 20th Sep 2007, 13:20 -
TmpgEnc 3 - stop it from encoding 544x576 ?
By katykaty in forum Authoring (DVD)Replies: 3Last Post: 10th May 2007, 17:06
