Are we able to burn VCD that enables forwarding or rewinding?
any advise would be appreciated.
thanks!
If you play them on a dvd player it is equiped with the function as far as your computer goes unless you put a chapter selection on it i dont believe you can.
Fast forward and rewind should work just fine on your DVD player. The only problem I've seen is with my Apex brand player, it FF/RW VCD fine but has a problem with SVCD's. I've heard there's a workaround, but haven't messed with it myself as I use only VCD.
AviDemux Fast Forward and Rewind
By MJS in forum EditingReplies: 2Last Post: 2nd Feb 2011, 07:16 -
Sumvision Phoenix will only fast forward or rewind some files.
By muay in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jan 2011, 08:01 -
Joining FLV videos -- playback problems with rewind/fast forward
By gumbygum in forum EditingReplies: 0Last Post: 30th May 2010, 16:32 -
How to Enable a Title for Fast Forward - Rewind?
By Nocturne in forum Authoring (DVD)Replies: 3Last Post: 28th Jun 2008, 00:46 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 22:48
