  1. just downloaded spiderman from kazaa to a vcd, although when i tried to play it on windows media it came up with this notice "Unable to download an appropriate decompressor" what does this mean and how can i fix it? also is there any other program i should use insted to play it ??
    wasup
  2. It's probrably a divx file you need to download the divx codec. Look under tools on this site, there you will find many codecs.
    Craig
  3. Also you may need the MPEG-4V3 codec. Many movies I found arent divx but mpeg 4, they are similar but different. I had the divx codec installed and still couldnt play a couple of movies I got, so I checked the file and it said they were mpeg4 V3. I downloaded a codec pack and it fixed it. Just about any pack will do just as long as it has the codec.
