If programs like Nero can burn without them? Or maybe i'm missing the concept of it? What's it really for anyway?
A cuesheet is a configuration file for your disc in which you define
the files to be recorded and the starting time of each track and
index. The cuesheet gives you complete control over the layout of
your disc. Every burn software use cuesheets, but most of them don't let you create/edit a cuesheet manually. -
So when you burn an image of say a hard drive backup onto a CD-R, it uses a .cue sheet, but you just don't know about it?
Also, when you create files to be burned (for example - making a VCD), Nero or a burning software creates the .cue sheet without your knowledge (this makes it sound like it's bad) and performs the task? -
Yes, too bad, that these companies think, we were all too stupid to work with a cuesheet. I love it to have the full control over the entire process, that's why I use CDRWIN all the time.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
How to burn or extract some CUE or APE files?
By diets in forum AudioReplies: 3Last Post: 21st Jan 2010, 11:43 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
Toast error message on .cue files
By Going gray in forum MacReplies: 8Last Post: 17th Aug 2007, 13:46 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
