Ok, is there a way i can extract the sound from divx files using virtualdub
mine just says unrecognised decompression, or words to that affect , i realise that the sound on divx is super compressed, just wonderd if there was a plugin,.......etc ?![]()
Depending on where you got your DivX from, there is often an info file with it, which will often specify the audio format used. Sounds like you might have ac3 or ogg sound, presuming you can't select audio>>full comression and save the audio as wav. If you can play the DivX with sound in some other player, this is quite probably the case, and you should check out the guides here for extracting sound other than mp3 from an avi. If you can't play it at all with sound, the first step is to acquire the necessary codecs to allow you to hear the sound.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
