i have managed to make a few vcds, however my last 10 attempts have failed, my dvd player just comes up as 'cd' and plays nothing. i think the problem is in my encoding what does one do when its not a straight forward divx with the right sound. i have movie which is this 704x384,
divx 5, 23,976fps. sound is 48000hz channels 5 stereo compression unknown tag. can this be converted or am i wasting my time? i use tmpg, virtua dub, goldwave and xfiles inc thanx
Use BeSweet to extract the 5 channel audio and convert it to stereo wav format. Use that as the audio source when converting with TmpGenc. Also, as the source is 23.97fps be sure you select the NTSC film template. That should do the trick
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
