does anyone use GQ (great quality) CD-r media from frys? these last 2 batchs i have bought recently have been giving me errors. i use them with NERO most of the time. whenever i try and burn a VCD/SVCD i get this "no seek complete" error. i never got this before. i use nero 5578. if anybody has any info for me it will be greatly appreciated
i'm having the same problem. before, i was using Nero 5.5.7.8, and it was working perfectly fine with all the CD-R(W)s i put in it.
my CD-Rs are the 700MB Circuit City brand.
my CD-RWs are the 700MB Memorex brand, which burns only at 4x.
both of these brands worked perfectly fine. then during one burning session, when i was burning onto my CD-RW, Nero just stops burning and says "No Seek Complete". the Nero website said it had to do with the brand of the CD-R(W).
well, this confused me because, how can a Circuit City CD-R be better than a *MEMOREX* CD-RW?
i knew this had to be a mistake. so i upgraded to 5.5.9.0. same problem. i upgraded to 5.5.9.17, which is the latest. still the same problem.
anyone have any suggestions? -
well, i tried converting the .mpg to bin/cue with vcdimager. then i tried burning that bin/cue with nero, fireburner, and diskjuggler. none of them would burn it.
so, i'm starting to think that i've probably changed the settings to my burner somewhere.
by the way, i have a Sony CRX175E.
CUDA seek time
By coolxal in forum Software PlayingReplies: 2Last Post: 9th Sep 2011, 23:03 -
FLV1 seek problem
By jenova in forum Newbie / General discussionsReplies: 8Last Post: 13th Jul 2010, 22:00 -
Seek Failed
By zeke1312 in forum Video ConversionReplies: 1Last Post: 20th Mar 2008, 07:59 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28
