I downloaded a movie. It is in AVI format. When I try to open it in TMPGEnc it says "illigal format". What do I do now?
OK---Windows Media Player will play it. DivX 2.0 Alpha says "Failed to Open". VirtualDub says "Couldn't locate decompressor for format 'MR42' (Microsoft High-Speed MPEG-4 V2) "
Are you able to play the AVI with Windows Media Player? If not, you're lacking the appropriate codec, most probably one of the MPEG-4 family.
If you CAN play it thru WMP, I have no idea. Maybe TMPGEnc just doesn't recognize whatever codec the video was encoded with for some reason. Try converting it to an AVI with a different codec and see if that works. Indeo is generally pretty good quality.
C h a o j i
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 08:46 -
Trouble Converting TS to MPEG
By Somebody2 in forum Video ConversionReplies: 2Last Post: 14th Jul 2010, 19:30 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 19:36 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 12:07
