I have a SVCD in PAL format that I want to convert to NTSC format. I read on this site that you can use TMPGenc to convert, but TMPGenc can't read the original SVCD MPEG file or DAT file.
The only way to play/view the SVCD is using PowerDVD on my computer (which is okay), but my goal here is to convert it so I can watch it on my DVD player.
Does anyone know of a way to convert from PAL to NTSC from a SVCD CD?
Thanks for any help!!
Install the MPEG-2 codec located in the Tools are in the menu to the left.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
PAL to NTSC Conversion with DD
By cottage in forum Video ConversionReplies: 5Last Post: 16th Feb 2009, 16:10 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
