Just as the subject says, when I try to open a .vdr file in cinema craft encoder to encode my avi and resize it at the same time, it either freezes or most recently, after I reinstalled cce, it says "not an avi file". I know that it is supposed to open, any suggestions?
Just drag and drop the *.vdr into the cce window. You should tell us, which VD, CCE versions you use, CPU, audio yes/no and all that. Sometimes it helps to read the frameserve guide.
Thanks. I'm reading the Frameserve guide that you posted in your first post to see what i'm doing wrong. I'm using virtualdub 1.4.9, cce 2.50, no audio. I am going to see if dragging and dropping the file will load it without freezing cce.
Okay, I followed the directions on the frameserve guide, and selected my wave file before I started frameserving, then dragged and dropped the vbr file as you suggested. This allowed me to open the file!! I am going to do a 4 pass encode, and post my results. Thanks for your help Truman.
L.
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 21:39 -
Lost ability to use Avisynth script to open .flv file with virtualdub.
By DaneClark in forum Video ConversionReplies: 4Last Post: 20th Feb 2011, 11:33 -
VirtualDub will not open Lagarith file
By StrobeLightEpileptic in forum EditingReplies: 14Last Post: 24th Jun 2010, 00:09 -
How to open a small flv file in virtualdub?
By Wizard81 in forum EditingReplies: 4Last Post: 20th Nov 2009, 12:14 -
vro on file on my panasonic vdr-d150gn
By vpholdie in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2009, 19:05
