Hi there,
Does anyone here have any real VCD experience with the Instant DVD?
I'm looking for something that would offer excellent encoding quality in both MPEG-1 (for VCDs, which I'm producing now) and MPEG-2 (for DVDs, which I don't "do" yet)
I saw in other threads some people have complained about the fact that the MPEG-2 encoding might still be buggy for times that exceed 45 minutes, but strangely, nobody mentions the VCD quality, and in general the real goods on the card when it comes to simple MPEG-1 stuff. And of course, the capture section is under maintenance...
So I'm wondering if you guys might have extra details.
Thanks.
I used the Instant Dvd for 6 months making vcd's didn't have any problems with vcd's quality is not as good as can be expected compared to dvd quality . My only problem with vcd's is the amount of movie on them, I have to use 2 cd's for a 2 hour movie and someone in my family will loose one of the set
Using it for DVD has produced several problems but ads does support their product with upgrades that do fix the problems. -
The ADS instant DVD's VCD quality is not very good at all. Static images show WAY too much compression artifacts compared to something like the ProVideo PV-231 and PV-233 cards. The DVD MPEG 2 setting looks very good with the Instant DVD, but SVCD's don't look that great as the the SVCD setting tends to have vertical lines at the edges of things like faces. The Instant DVD's Mpeg 2 files are also nearly impossible to cut without losing sync.
Firewire and USB 2.0 Cable quality - does it matter???
By tarrickb in forum Capturing and VCRReplies: 21Last Post: 29th Mar 2012, 13:59 -
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 19:57 -
USB Instant DVD
By bolintx in forum MacReplies: 1Last Post: 31st Jul 2008, 15:17 -
videoCD to dvd
By rubberman in forum Video ConversionReplies: 9Last Post: 31st Jul 2008, 14:59 -
Why does firewire seem clearer than using ADStech instant dvd usb 2.0?
By jbitakis in forum Capturing and VCRReplies: 5Last Post: 20th Sep 2007, 04:12
