  1. Hi,
    I am trying to convert some DivX films to mpeg so that I can burn them to VCD. I have followed the guide but still to no avail.
    Some DivX's will start converting in TMpeg, yet after conversion, a totally black screen mpeg will be produced with audio. Others will convert fine on the video side, yet have no audio.
    The DivX's play fine thru Playa or WMP.
    I would appreciate any help I can get !!
    Adam.
  2. make sure you have all the codec from the Vcdhelp tools section installed in your pc. If you hear the sound but no pic it's codec 9 times out of 10
    o(-_-)o---------------------------------------o(-_-)o
  3. I have the same problem with Spiderman movie.....it encoded fine with tmpgenc to pal standard mpg but audio only present for the first few seconds after encodeing. If i play the movie as compressed avi it plays fine with audio present from begining to end.....can somebody help me cause i have been trying for 2 days now.......
