Results 1 to 14 of 14
  1. How do i record VHS's from my computer? do i need to use a VCR?
    Sep 2000
    Northern Virginia
    yes, you need a vcr to record to vhs tape.
    Jul 2001
    lancashire
    ER ! r u all there ?
  4. How do i use a vcr to do that? What do i do? do i need some special equipement?
    Jun 2001
    uk england & proud of it
    what you need is special help from a doctor
    Jul 2001
    Go to this site! It will Help you!
    http://www.techtv.com/callforhelp/answerstips/story/0,23008,3308675,00.html
    You have to copy and paste the address...
    <font size=-1>[ This Message was edited by: Feslmogh on 2001-08-09 14:33:29 ]</font>
  7. Assuming you mean TO your computer: Try 'Movie Maker' from Creative Labs. Attach it to the outputs of your vcr and to your computer via the device's USB connection. Just play a tape and click 'record'.
  8. hey,
    There are complete guides on how to capture convert and burn VCD XVCD SVCD XSVCD MiniDVD and DVD.. There is also a list and comparison of capture cards... I suggest reading the guides to the left of this page, its probobly the best help you can get...
    Matthew
  9. My question is: How can i record to my VCR from my computer?
  10. um, connect yer lead from the vcr to yer tuner card, then open up yer tv application and scan for the vhs channel (gotta play a tape while scanning) and it should find it, then save the channl as vcr or summant.
    i did this
  11. I see waht you mean.. You need a video card with tv out connected to your vcr (along with a sound cord). That should allow you to record to your vcr from your computer.
    Time and technology are very similar... you can't stop their progress, and you can't undo the mistakes.
  12. u need a capture device with OUTPUTS like the dazzle digital video creator II. then u attach a/v/cables from the output of the dazzle to ur vcr play the movie on dazzle software & record on ur vcr
  13. Well if you want to record your movies FROM your COMP to a VHS TAPE you will need to get yourself a video card that has VIDEO and AUDIO OUTPUTS. I have one installed on my comp called The All IN WONDER which is a great video card. I have used this to put over 100 movies ROM my COMP to VHS.
  14. A simple way is to connect one cord from audio-out on you sound card to audio-in on your video for that you might need one audio jack-to-RCA cord then use a video RCA-to-RCA cord to connect from video-out on your VideoCard/TVCard to video-in on your video.
    Yeah u need to have a card with video-out
