when i follow the steps of putting subs in my avi using vdub 1.4.10 i seem to have a problem when i start frameserving.I have installed the handler as described.It doesn't seem to start serving ,I mean the numbers keeps zero...Since it is the first time i am trying to work w/ subs I asking if this is normal.subfilter is installed and subs are in ssa btw.
os is win xp.
If you only start frameserving, nothing happens, that is normal. You have to load the *.vdr into your MPEG encoder and start conversion.
had an error when loading the .vdr file into tmpg it couldn't find msvcr70.dll.Anyone has this prob?
I downloaded the missing file at http://www.logoslbe.com/
perhaps usefull for anyone who has the same problems
