In Virtual Dub when I capture I drop frames and the CPU usage is only at 10%. I am capturing using HuffyUV, 352x240.
I have an AMD Thunderbird 900 Mhz
256 megs of ram
30 gig 7200 RPM hd
ATI All In Wonder Radeon 32 MB DDR
I don't think that the audio is a factor.
Can someone help me out here. I really can't have these dropped frames
Any Tips?
Eric
What is the source you are capturing from and how many frames are you dropping.
Craig -
Check for a bios update. I had the same problem and it turned out to be a bug in the bios that was running the hard drives at 33. Once I upgraded the bios, my frame drop problem went away.
Ok Thank You, but could you please tell me where I could check for a bios update?
Thanks!
Eric -
You can usually download free new bios updates from your motherboard maker's website. My MB is by Gigabyte, and I downloaded my bios upgrade from them. Check to see what your current bios version is by re-booting. Be sure you get the correct bios update for your bios.
ffmpeg CPU usage
By diprotic in forum Video ConversionReplies: 13Last Post: 19th Apr 2015, 15:40 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 10:59 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 18:09
