Hi,
I would like advise on a wedding project I am trying. I have about 190 JPG images taken with a Canon S30 in 1600x1200. I am using Roxio VideoPack 5 to create a slideshow with transitions and with background music and saving this in MPEG-2 NTSC format.
Then I use Ulead MediaStudio Pro 6 (video editor 6) to take the MPEG-2 scene and putting them into sequence with an intro MPEG-2 and a menu base with background music.
My problem is when i save this project in VCD format and burn it to CDR, the quality of the JPG images is not very good.
I'm I using the rong software to encode the images and music to MPEG-2 and/or should I do everything in AVI than encode to MPEG-2 with another software?
I have created 7 coasters now and getting really anoided of the pour quality.
Can some one tell me what i'm doing rong and/or what tools I should use in order for my JPG photos to be of a good quality.
I saw something in Ulead Video Pack that talks about video bit rate and I have it setup to 1x. Is putting it in 2x or 4x going to be better?
Regards,
NPereira
Sorry, I haven't used Roxio VideoPack 5 before, but I had similar results when I tried to make a slideshow in nero. The image quality was horrible, then I tried Ulead DVD picture show and it looked much better. I think it uses the still image feature in VCD 2.0 to save the images so its a full 720x480, I dunno what nero does, but it doesn't look quite as good. Anyway, bottom line: Try Ulead DVD picture show. They have a trial version on their website.
http://www.ulead.com/I will not eat oysters. I want my food dead - not sick, not wounded - dead.- Woody Allen
fonoop.com -
Originally Posted by npereira
I dont much about roxio video pack5, wherther it allows you to save AVI format. I would save the movie in AVI format, divx5 codec, and use dvd2svcd to convert it to mpeg2.
Looking for advice on how best to start a project
By paulocon in forum DVD RippingReplies: 4Last Post: 6th Jul 2011, 04:19 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Restoration project: Need advice buying a decent VCR.
By nicknick in forum RestorationReplies: 35Last Post: 12th Apr 2010, 10:14 -
Sanyo Xacti VPC-HD2000 AVCHD Newb - Video Device Project Advice
By raverscout in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 8th Oct 2009, 08:37 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49
