I'm a total newbie here so please bear with me. I have a movie in a DAT file that plays really well in Windows Media Player. The problem is that the audio only comes out of the left channel. What does come out is in mono so I'm not missing any of the sounds. I just want to get it to play out of both channels. Help me Obi-Wan, you're my only hope!
thats a bad rip
you can correct it - but as a newbie it might not be the easiest thing for you to do -- I know there is already a few posts in this forum about how to fix it (just serach for them)
you have to de-multiplex the file - edit the audio then re-encode the audio and multiplex it .... as I said it's not easy
look for the previous postsyour pal,
Stinky
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12
