i set up an svcd template in TV capture program that comes with the
ATI Radeon. i was able to capture in 2.51 Mbps SVCD 480x480 mpeg2.
i burned it and it was great. but all of the sudden, whenever i capture
with my custom setting, i'm unable to play any mpeg2 i record. the
captured file using the good quality, vcd, etc. that comes with the
TV capture program plays fine - it's only when i use my custom svcd
template. it worked before but not now. PLEASE HELP!!!
THANKS in advance.
Where are you trying to play the SVCD's ? you have to use either the ATI File Viewer, DVD software or install an MPEG-2 codec to view them in MS Media Player. --- that is if I understand your question correctly.
SVCD's are MPEG-2 and are different than VCD's which are MPEG-1 and will play very easily in most any software player.
The VCD preset in MMC is actually lower than what the VCD standard is - you can grab my MMC tool from the tools section - it has some good presets in it - that you might find helpfulyour pal,
Stinky
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
ATI Catalyst MC - Custom Profile options?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 11th Jul 2009, 12:30 -
Custom Video Converstion Help 720p to custom 720p
By powerplyer in forum Video ConversionReplies: 5Last Post: 4th Jun 2009, 15:14 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Custom chapters
By Clarky_man in forum Newbie / General discussionsReplies: 3Last Post: 27th May 2007, 09:42
