here is the information for my cd-rw:
http://ca.lgservice.com/bin/HPI/HpiHomeMain.cgi
can u tell me that if my cd-rw can do overburn SAFELY?
coz i need to burn a 7XX dat file to a 800MB cd-r...thanks!!!
check the cd writers list at the left.
btw the link was no goodWell, I am the slime from your video.
Oozin' along on your livin'room floor. -
thx for your reply first!!!
my cd-rw is LG (CED-8080B)
and they don't have it on the cd writer list, so.... -
it should be able.
http://www.pcworld.com/reviews/article/0,aid,16890,pg,9,00.aspWell, I am the slime from your video.
thank you for finding me that article
it really helps!!!
so am i set to go now??
please give me any suggestions b4 i do it!!!
i'm waiting for your response :P -
i suggest you search the forum.
what is the dat file of yours, if its vcd you can not just burn it.
vcds and svcds have to be authored from the mpg.
if its vcd you will also need to use vcdgear on it.Well, I am the slime from your video.
If you want to overburn, it's best to buy some 90 or 99 minute cdr's. I have 2 burners, a HP 9000I, and Lite-On 32123S, which was built specifically for overburning. Even with the Lite-On, over burning more than 1 minute is a real problem unless I use a 90 or 99 minute CD. With the longer cdr's, I never run in to a burning problem and the vcd's play fine on my Apex 500W.
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 02:54 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 10:08
