I'm using Flask and the Panasonic plugin to creat my VCD mpegs.
I've got some questions about the image filters.
1st) Noise Reduction:
The filter has three levels, should I be using the strongest?
2nd) Video Filters:
The filter has two modes: fixed and adaptive, each with variable intensity.
Currently I'm not using this filter because the help file said that the image may become blurry. Should I be using this filter and if so, what settings?
Any help / info is greatly appriciated.
Gordo,
Any answer provided would be a reflection of our personal preferences. Basically what I consider to be 'best' might be crap to you. Try creating small video clips that you can remaster using serveral combos of filters to see which ones pleases you most.
As a rule of thumb the better your source the less filtering you will need. In my case since I use DVD sources I use basic filtering for comedies/drama and adaptive filters for fast action movies. The reason is that the VCDs low bitrate causes really bad motion artifacts that need to be drastically softened.
Thats my 2 Cents, Hope it helps.
D
Can anyone recommend any good general Internet / Computer Help Forums?
By jacknscoob in forum Newbie / General discussionsReplies: 10Last Post: 22nd Jan 2012, 06:38 -
General Discussion: Some good investments for Video Authoring/Hardware
By Krelmaneck in forum Newbie / General discussionsReplies: 6Last Post: 19th May 2011, 03:25 -
Compression Settings General
By oc6088 in forum Video ConversionReplies: 13Last Post: 7th Oct 2009, 22:14 -
ac3 filter settings questions
By THX-UltraII in forum AudioReplies: 0Last Post: 11th Feb 2009, 06:32 -
some general MPC settings questions
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 08:28
