As you can see by my username, I am a Transformer collector.I have a lot of the old TV episodes on VHS, but seeing as how VHS deteriorates over time, I decided to start burning them into VCD in order to preserve them better (I'm a cheapie and can't really afford the DVDs though eventually I will probably get them.
). I captured them using iMovie 2 then saved them in full quality using the Sorenson Video codec. I then used Toast Titanium 5.0.2 to convert them into MPEG format, then burned them onto a VCD. Now, the .mpg file that I'm burning from is complete; yet when I burn it to the CD, the last 1-2 minutes are GONE. I'm using 700MB CD-Rs to burn onto, and the file I'm burning is 627MB, I should have enough room on the disc. What's going on? Thanx in advance.
It's really wonderful to find a Message Board forum that deals specifically with Mac oriented stuff!
Am I the only one that's experienced this? -
I've never experienced that problem before. If you watch the mpeg before you burn is the whole video there or are the last minutes still cut off?
Transformers is being released in complete season packages on DVD starting ... like in the next few weeks if not right now.
tgpo, Yes I did view the entire movie before I burned it, and it's all there. That's what makes this boggling to me...
AntnyMD, yes, I knew about the TF: Season 1 DVD box set; it's just I can't afford it right now.
Thanks, though.
VHS to DVD - Question out of curiosity...
By nharikrishna in forum Capturing and VCRReplies: 3Last Post: 25th Nov 2010, 04:04 -
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
How can i burn a DVD or VCD with subtitles?
By Krimoon in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2008, 15:41 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 18:49
