Do these cards that can receive free to air digital broadcasts in the UK capture the video directly as its broadcast or does it involve any recompression?
What I mean is does it simply save to your hardrive the mpeg 2 stream exactly as its broadcast?
If so what kind of data rate are they broadcast at?
How much space would a half hour show or a 2 hour movie take if captured this way?
The hauppauge site isnt very clear on exactly what these cards do hence my question
thanx ahead![]()
The Nova and Nexus both receive files in their actual broadcast mpeg format. I believe the Nova allows you to receives all FTA terestial channels from a [high gain] TV aerial, like BBC1, 2, Choice, Four, ITV2, etc. The Nexus allows you to capture FTA from a satellite dish; you can also get a CAM to allow pay channels, but I don't think it'll work with your Sky card (though correct me if I'm wrong....!)
The Nova doesn't have a CAM, so I don;t think it could get the pay TV channels from ITV Dig prior to it going bust (though apparently it found the channels on setup, so there may have been a crack).
I'd avoid the USB model though.....can't imagine it being able to move enough info across.
Have a look at http://www.hauppauge.co.uk/html/digitaltv_prod.htm[url] for more info.
If you're looking for a TV card just for these channels and to use as a PVR, this card would by far be the best.....
Flash Cards Secure Digital
By chewie8008 in forum MediaReplies: 3Last Post: 28th Jan 2011, 13:08 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 01:21 -
Moving from analog capture card to digital. Focus on cards with DVB-C (US)?
By ColKurtz in forum Newbie / General discussionsReplies: 6Last Post: 19th Aug 2008, 22:25 -
Feb 2008 Analogue to Digital and back again .. PVR cards
By bendixG15 in forum Newbie / General discussionsReplies: 9Last Post: 10th Mar 2008, 17:35 -
Name Brand SD Digital camera cards vs off brands...
By chewie8008 in forum Off topicReplies: 3Last Post: 4th May 2007, 20:58
