Please help. I've been trying a vcd hack on my zenith 2250 dvd player, by using the 2200 hack and the secret menu will pop up, but when I am finished with the procedure, it still reads disc error when trying to play a vcd. This is the procedure I've been using.......
VCD Hack
1. Power on the player with no disk in the drive
2. Press "PAUSE" on the remote
3. Enter "1472" on the remote (the characters 01 47 should appear on the display)
[If your player is a non UK model, this number will probably be different]
4. Press the UP arrow three times (the characters 04 Fd should appear on the display)
5. Press "PROGRAM", "6", "PROGRAM", "5" (the characters 04 FE should now be displayed)
6. Press "ENTER" (the display should flash briefly)
7. Press "RETURN"
8. Power the player off and then back on
9. Play a VCD!
I've even tried using an audio disc when attempting the procedure and still NO positive result. Please help. It seems that if the "secret" menu appears, a vcd hack should be possible.
'kathleen
Results 1 to 1 of 1
Hauppauge 2250 Tuner Card Aborts Recordings
By rixware in forum Capturing and VCRReplies: 8Last Post: 30th Jul 2012, 13:14 -
WinTV-HVR-2250 TV Tuner
By Richintx in forum Capturing and VCRReplies: 18Last Post: 23rd Mar 2010, 00:36 -
Hauppauge HVR 2250 won't work with PCIE 2.0
By latichever in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2009, 09:18 -
Has anyone tried the Hauppauge 2250 yet?
By TooLFooL in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2008, 05:07 -
Zenith XBV442 Region Free Hack Help
By dual in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th May 2007, 23:30
