Nero still shows the resutant files as 352 x 288 even though you I used the Video arrange method at 352x320???? Shouldn't Nero be showing something different than the PAL setting since we corrected for the PAL AR??? Do we tell Nero to use PAL or NTSC???Originally Posted by banjazzer
I didn't find this to be the case. I had to use DVD2AVI. I have the MPEG-2 codec for TMPGENc but still needed DVD2AVI for no failures. Yes I did use VCDGear to fix the errors.Originally Posted by Stinky
BTW, If compliancy isn't an issue, should we always convert to XVCD (as oppossed to compliant VCD) and take advantage of the extra quality and remaining disk space on the CD-R??
Also, In the "Newbie how to burn a movie to a single CD-R" guide, they have some talk about sometimes successfully burning (at a fast speed) with Nero but only to have video problems. They say to burn at a slower speed. Do I now have to be paranoid about successfully burning at my CD writer's fastest speed of 16x????
Results 31 to 35 of 35
Also, In the "Newbie how to burn a movie to a single CD-R" guide, they have some talk about sometimes successfully burning (at a fast speed) with Nero but only to have video problems. They say to burn at a slower speed. Do I now have to be paranoid about successfully burning at my CD writer's fastest speed of 16x???? -
The video arrange method setting is to adjust the aspect ratio with this particular movie. However, we are still producing a PAL VCD-compliant mpg which will be 352x288 as shown by Nero. It doesn't matter whether you select PAL or NTSC in Nero - it takes the mpg as it finds it. The PAL/NTSC setting is for when you use Nero's internal encoder (not recommended).
As to burning speeds, this really depends on the media and the individual DVD player. Some players are more fussy than others - it's a question of suck it and see! I always use 8X. I find faster than this doesn't in practice actually burn much faster because of the limitations of my system. In fact it would be interesting to know how many 16x burns would be successful without using buffer underrun protection. 8) -
That explains it, Thanks much!!!Originally Posted by banjazzer
Nero is the only burning software that I've used that can successfully burn my HP9700i burner at 16x on my system. Ulead products and EasyCDcreator only can handle 8x on my system. So maybe the safest bet is to only burn at a speed that all burner software can handle (even if Nero says "successfull").Originally Posted by banjazzer
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06
