tmpgenc will not let me load mpa files from dvd2avi
so how can i convert to wav not using virtual dub whilst still retaining quality
Easiest way for me
open WinAmp - drag the file in
go to Options->Prefrences->Plug-in's-Output
select Nullsoft Diskwriter -- hit configure and select where you want the WAV file to be saved
close out of all the windows - press play on WinAmp -- it will convert it to WAV (pretty quickly too)
just remember to reset WinAmp back if to wavOutput if you use it to play mp3'syour pal,
Stinky -
Why are you converting from mpa? mpa files should input into TMPGenc.
they should but the truth is a lot of times they dont
even on my own system sometimes I can't force TMPGEnc to take them - instead of fighting with TMPGEnc it's easier to just convert ityour pal,
Stinky
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 08:34 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 14:12 -
using VOB2MPG to convert WITHOUT the commentary audio track
By wildrthanevr in forum Video ConversionReplies: 4Last Post: 16th Mar 2009, 11:57 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 19:07
