  1. Hi all! I've been editing an avi file with premiere 6.0 , and after a big, very big editing, i've record my project . But, when i've tried open it again, oh no ! in timeline all have been dissapeared , and in the project window there aren't my files , only appears '-1" several times.
    Please, help, help, i'm desesperated , there are hundred of hours in this job... i want to recover it.
    please, give me hope
    thanks a lot
  2. don't fully understand your post, but it sounds as if the source files aren't in the same location as they were when you were editting, have you moved or deleted the original source files? This is a mistake I made after completing an edit job in an attempt to save harddrive space! Do you have the final AVI saved? can you not recover from that? Also if you look in your premiere folder you should find the folder relating to your project and if the files aren't in there, then I think they're lost!! sorry!
    Good luck,
    Raji
