Can any1 please tell me the best way to make a VideoCD by only pressing one button?
The other thing: It should take longer than 4 hours to rip a 2 hour movie.
Any help is well appreciated
EE
8)
There is as yet no one button device I know of where you don't have to extract etc etc sound etc etc encode to VCD. There is one someone has mentioned to me but I haven't seen it yet. The process does take time anyway as it has to slow down the film and select frames from the vob file so that it can make a smaller film. VCD Galaxy is at the moment the simplest thing I have used to date. -
DVD2SVCD is really simpel. and i think that with newer versions you can do vcd, not sure.
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
There is a one button method to copy a disc - put it on the xerox machine & press the big green button
If you want something good you have to work at it.
Try DVDx or DVD2SVCD
True artists don't copy other artists but craft their own masterpieces -
there's a hardware called terapin (or something like that) that connects to your dvd player (or TV...not sure exactly how it works)...but it copies the DVD onto a standard VCD 2.0 for you directly (no need to rip or do all that other stuff on your computer)....
the terapin is a standalone device...
however, it's hella expensive (at least the same price as a DVD-RAM)..and only makes standard VCD 2.0 (crappy resolution and bitrate) -
DVD2SVCD is the answer!
Once you set some parameters on the first run, from there on it's a "One Click"!
The new version supports VCD's and SVCD.
And also predicts CQ mode values for TMPEG!
I'm testing it right now.
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net
key press on audio program required
By igor_video in forum AudioReplies: 0Last Post: 16th Jan 2012, 10:29 -
old Memorex apology press release?
By lordsmurf in forum MediaReplies: 15Last Post: 9th Dec 2009, 13:30 -
HELP! When i press encode it asks where is process.app?
By kanis2306 in forum ffmpegX general discussionReplies: 6Last Post: 11th May 2009, 14:03 -
What video lighting setup for Press Conference room ?
By AAC in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2008, 11:38 -
videoCD to dvd
By rubberman in forum Video ConversionReplies: 9Last Post: 31st Jul 2008, 13:59
