I capture alot from tv in avi with virtualdub after that i convert it with TMPGEnc to mpg1 then i cut all the crap out then i put it all together again.
Now i can burn this to vcd using nero it wil say its not standard but if i skip that and burn it annyway it works just fine but if i reincode it and then burn it with nero i wont say annything and its smaller now my question is do i allways have to reincode mpg files that have being cut and join ! the are smaller and nero dont complain but is there a faster way to this...
You want to do your cutting before you do your encoding. Open your AVI file in virtual dub then select the start and end point of the bits you want to cut out, adverts etc, then press the delete button. That portion of video is then removed from the timeline, although it is still there in the AVI file. Then frameserve to TMPGEnc, your mpeg will be created with the adverts removed. Much quicker way of doing it an no need to cut and merge your mpegs, which I find can give an annoying pop sound at the point of the merge.
Craig
Why do I have multiple files when I convert HD to SD using Tmpgenc??
By Endoking01 in forum Newbie / General discussionsReplies: 12Last Post: 9th Jun 2010, 21:43 -
TMPGenc CAN NOT CONVERT AVI LF RT CHANNELS TO 2 AUDIOS
By suijaypao in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 05:03 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 16:53 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57 -
Convert to Zune compitable Qucktime using tmpgenc 4
By frogman54 in forum Video ConversionReplies: 1Last Post: 14th Jun 2007, 14:21
