Ok i got my apex ad-3201 and i burned a movie to cd-r, i am able to see the picture..(blocky though) but no sound!
what should i do? is it the way i convert? or author?
any advise would help.
When you encoded the mpeg did you make it vcd compliant. It may be that the audio in the original AVI file is compressed. If this is the case you need to extract the audio to an uncompressed wav file (you can use virtualdub to do this). Then when you encode using tmpgenc use this wav file as your audio stream.
Craig
VOBs burned to DVD have sound missing on TV (but play OK on PC)
By martinlest in forum Authoring (DVD)Replies: 3Last Post: 29th Mar 2012, 06:17 -
Burned dvd video disc has no sound
By funnybunny in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2008, 15:00 -
no sound on a burned dvd
By kissy in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2008, 18:38 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21 -
Sound Loss on Burned AVI Flics
By RailheaD in forum DVD & Blu-ray WritersReplies: 24Last Post: 11th May 2007, 11:41
