i'm trying to encode my .avi copy of episode 2 onto a vcd. However, the specs for this movie are 352x176, and 20,000 fps. This translates into a decent but very small screen when watching the movie. I have made many vcds, but have always stuck to the tried tested and true easy methods to get a simple result. However, I would really like to get this in good quality. What is the best way to increase the clarity of the picture for use in a standalone dvd player. I usually use, virtualdub, Tmpgenc, and vcdeasy as my main programs to create. Any sound advice? If so, any specifics on how to obtain this?
Well you have a lower than standard (for vcd) resolution and framerate, so creating a good quality VCD is not really possible. Basically you dont have the quality there to start with. Crap in = Crap out.
PS I assume the framerate is 20fps and not 20 thousand fps
Craig
ultrafast vs slow preset in x264, and the resulting visual quality
By codemaster in forum Video ConversionReplies: 4Last Post: 22nd Jul 2014, 15:54 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
Low framerate after BD encode
By h41cyon in forum Blu-ray RippingReplies: 3Last Post: 24th Mar 2008, 00:34 -
H.264 Stream (Premiere HD) converting problem with SVCD2DVD - Low Framerate
By mickj63 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 3rd Mar 2008, 07:44
