    May 2002
    Toronto
    hey guys
    how do i reduce the size of my avi (divx) files. i have phantom menace at 800 mb etc. i can cut with vdub but i wanna put it on one cd. please helpppppppppppp
    thanks
    Success is never Final!!!!!!
  2. Get a 99 minute CD-R. They can hold 1 gig.
    Aug 2001
    Västerås, Sweden
    you might want to make sure your burner support them first.
    you can check the CD Writer list to the left.
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
  4. load the file with virtualdub and go to file -> file information... look at the bitrate and just reincode with a 10-12% lower bitrate to make it 700 megs...
