  1. It seems REALLY EASY to use and has many optional formats to capture in. I have been using it and doing the DV-AVI 25mbps.
    I have found that capturing a 45min DV video makes a 20 GIG AVI. Does this sound bout right? I thouht it was HI for DV to AVI.
    hmm
    any one else using this program.
  2. i am unsure the answer to your question but i have a comment. i havn't tried the XP version but from what i have heard it is an awsome capturing and encodeing program. is this true..i'm just curious cause i don't like the previous versions............
  3. Member holistic's Avatar
    May 2001
    here & there
    XP Movie Maker - in a word - JUNK
    Max res. In "Hi Quality" of all things is 320*240 - You are much better off using VirtualDub (requires a Dv codec to import)
    Somebody else has opinions ..
    http://www.am-softhome.com/articles/WindowsXP/WindowsXP.html
    DV = approx 3.7 Mb/sec = 222 Mb a minute = just under 10 Gigs for 45 minutes
    Your numbers are off.
  4. For pure 'capture' of DV, Windows XP movie maker works fine. Just select the relevant format (NTSC or PAL DV) and hit go. This is not a capture in the normal sense, but a copy of digital data from your tape to your HD.
    But holistic is right with the numbers and file sizes tho, you must be selecting the wrong format.
