Hi.
In tmpeg under the svcd template, I cannot change the audio bitrate as it is ghosted, is there a way I can fix this?
after loading the "SVCD" template, you need to load the "unlock" template. i believe it is located under the "Extra" folder.
new template "bitrate v1.6.XLS" released
By led in forum Latest Video NewsReplies: 1Last Post: 29th Jan 2011, 13:21 -
Difference in Audio Bitrate
By skorpinok in forum AudioReplies: 2Last Post: 29th Aug 2010, 12:47 -
Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.
By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 22:40 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 05:12 -
By akulier in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2008, 04:31
