Somebody please help me out here. I downloaded a bunch of movies in AVI format and now, whenever I run them, all I get is Audio, I know there is Video too with them. A friend of mine said you have to have the complete file. Well I do in some cases. How can I solve this problem?
I have tried using TmpgEnc to convert it to the MPG file, but the program gives me an error 'File "Filepath" can not open, or unsupported.'
Have you installed the divx codec? And you can also try the new divx codec and play with the playa player(support broken divxs also) http://www.divx.com
i just downlaoded a couple movies with the same problem.. i thought they should work, 1 movie was in 2 parts, where the first worked like a champ, however the second was audio only.. i checked the resolution and noticed the second half was in pal format, should that make a difference?
On 2001-08-01 11:39:49, Baldrick wrote:
Have you installed the divx codec? And you can also try the new divx codec and play with the playa player(support broken divxs also) www.divx.com
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Yeah, I downloaded the codec this morning and tried playing the AVI files again. It still didn't work.
audio broken in all media files
By amarkudre in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2010, 03:14 -
HD recovery -> broken AVI files
By tcglog in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2010, 16:48 -
Broken AVI Files after data recovery "FFmpegSource: Couldn't find stream information"
By fixavifile in forum Newbie / General discussionsReplies: 8Last Post: 28th Jan 2010, 03:24 -
Newber: easiest solution 2 convert dvd (aud/vid .ts) from HD to NAS in MPG
By gizfs in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2008, 18:27 -
swf to avi - last few frames of animation get cut in the avi - any solution
By perfection in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2007, 08:01
