Greetings
I have a 640x272 AVI file that I would like to put onto a VCD. The problem is that when you view the AVI in Media Player it looks like wide screen, 16:9, letterbox. Then when I try to make the VCD, part of the picture on both side gets choped off and makes viewing hard.
I use TMPGEnc to encode the AVI to an MPEG first. But so far have had no joy getting a widescreen finish. Is it possible? If not is there some other way to encode it and make a VCD so that the edges don't get cut off?
Many Thanks
Brett
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
Wide screen
By breeze9 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2007, 23:31 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 13:41 -
wide screen
By ht0160 in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 17:52
