I have monsters ball and after converting, the audio get progressively out of sync. I believe the audio is in ac3 format. When opening the file in vdub, it shows the audio as unknown (tag 2000). Vdub will not allow me to save the wav uncompressed because "the compressions don't match" or something. So I took the audio decompressor from avi2vcd, uncompressed the file, opened the uncompressed file with vdub and split of the audio with a direct copy. I then used this audio and the original avi video and converted with tmpg. What do I need to do differently to sync the audio throughout the movie?
Are you sure that the framerate of the avi matches the framerate in the TmpGenc template you chose. This is a common cause of gradual sync problems
MXCapture program w/ Monster X - Audio Sync Issue
By Mysteriouskk in forum Capturing and VCRReplies: 3Last Post: 20th Jul 2012, 16:26 -
Audio syncing problem...
By Huntr777 in forum MacReplies: 3Last Post: 1st Aug 2011, 16:30 -
multiAVCHD syncing problem
By dan_man555 in forum Video ConversionReplies: 6Last Post: 30th Jun 2011, 21:41 -
audio syncing
By projecttemp in forum AudioReplies: 3Last Post: 9th Apr 2008, 21:11 -
audio syncing issues
By anap in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2007, 04:11
