  1. Hello,
    I have a ATI AIW Radeon, and am using Vdub to capture at 480 x 576 resolution, from a VHS tape.
    I had read some where that RGB32 (or RGB16) is better than YUYx but when I select RGB32 or RGB16 as video type, it says 'format not supported'. I am able to capture if I select YUV2 or YUVY. (or maybe even UYVY)
    Could you please tell me which format should I use. Is there any place where I can read what is the meaning of all these codes.
    Thanks,
    Roh
    Feb 2001
    The [Almost Definitive] FOURCC Definition List:
    http://www.webartz.com/fourcc/
    Microsoft's FOURCC for Video Compression:
    http://www.microsoft.com/hwdev/archive/devdes/fourcc.asp
    /\/\ars /\/\ayhem
