I have a windows xp pro computer with a leadtek winfast 2000 xp tv/tuner card. I can capture fine with this card, but avi_io and virtual dub only see my capture device as Microsft WDM Image Capture (Win32). My resolution setting in both settings (whether going to custom format) is set to only 320 x 240 resolution. My question is if any one has used this video card and knows of any newer drivers. I have driver version 5.0.0.24 from 1/3/2002 Leadtek research. I can capture at this resolution no matter what i try to capture from. svideo,tuner,rca composite. Any help would be greatly appreciated. I am going to be capturing off of my cable and also capturing off of my old vcr tapes.
This might be a shot in the dark, but go get the Detenator Drivers from Nvidia. I THINK.. NOT SURE.. that it has a nvidia chipset. It may help, but like I said.. I'm not sure.
This won't answer your question, but this is what I did- I just used the software it came with, and made a custon format in "Video Format" (size, codec, etc). I just select it and record- its worked great for me.
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 12:38 -
Winfast 2000 XP input jack is a PS/2?
By jabberdau in forum Capturing and VCRReplies: 7Last Post: 18th Nov 2009, 14:46 -
WinFast A340 Xbox Capture help
By lj106 in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2008, 12:10 -
Looking For A Windows 2000 Compatible Video Capture Device
By acid_burn in forum Capturing and VCRReplies: 16Last Post: 29th Nov 2007, 11:42 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 11:00
