After opening a file in VD, I get a message "warning VD has reconstructed the index for this file, but you have not specified rekeying in the extended open options dialog. Seeking in the file may be slow". Any advice for a newbie to correct this.
click ok then go to file and save as wave this will give u an uncompressed wave file then encode seperate to the vid
use DivXFix.
http://www.divx-digest.com/software/divfix.html
open up the file. strip then rebuild the index. you can check for error too if ya want.
thats all.later bater. deltaboy -
Thanks evryone for your help. I tried Divfix and successfully stripped and rebuilded the index, but now I am running into a different problem. While trying to run Virtualdub I am getting a message "the requested audio compression is not compatible with the input format. Check that the sampling rate & channel count of the input match those of the requested format"
Any advice for a newbie -
I guess I should also state that when I open the AVI file, there is no info next to the audio compression. I also have a fps of 14.985. Is it safe to assume that this file is bogus. This is the first time I am attempting this so any help is appreciated.
VirtualDub question
By s3r19lk1ll3r in forum EditingReplies: 5Last Post: 15th Oct 2010, 17:43 -
VirtualDub question
By Rogert in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2009, 12:22 -
virtualdub question
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 13:34 -
virtualdub question
By cowboysroy31 in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 12:50 -
noob question...about VIRTUALDUB....
By SeeNoEVO in forum Video ConversionReplies: 1Last Post: 1st Jun 2007, 02:07
