hi i am a noob in desperate need of help! i have a trv - vtr320 digital 8 camcorder. i made a new computer along with a new firewire card to make it work. now with premiere 6.0 i expected it to be as simple as 1,2,3 but that's not the case for me. i struggled with this thing for a week so i covered all the ground as far as basics are concerned like secure wiring, camcorder settings etc.
now when i try to capture anything, from the computer i can control the buttons like play, forward, stop. when it's playing, i get no picture and sound, and the buttons on the screen switches from play to stop back and forth, and the clock on the bottom goes on and off. and when i press record try to capture, it says device is not connected and it freezes up, sometimes even crashes my computer. i am going to try buy a new cable to check to see if that is the problem, which will cost me more than the card itself, but i don't know how it is possible to be able to control the buttons but can't record anything. this is freaking me out, i've done everythign i humanly can, now i'm begging for your help. ... HELP!!!!!
one simple question. is there any way i can digtize tapes on HI 8 setting with a firewire card and certain software?
tahnk you
camcorder: sony dcr-trv320.
premiere 6.0 ( under device driver, i put all accurate settings, it even has my cam listed, and status is online when i connect it)
athlon xp 1800 / kt3 ultra 333 mobo
256 2100 ddr ram
40 g hard driev
generic firewire card ( all drivers set, device manager shows it's working properly but i'm suspicious 'cause i got this thing for 20 bucks at the computer convention..... came with cable too)
G force 2 gts 32mb video
direct x 8.1
divx codec 5.1 (came with divx pro 2.0 )
built in 6 channel sound(it's working fine)
made the computer myself last week everything works much better than celeron 400 i had up my ass for last one year in everyway but just couldn't get it to work with this video editing thing. please help
ok i've figured it out...... i just enabled " work with non-supported devices" option that was under the driver setting.........
hmm. i feel much better now. let's get into video editing!!! uyay!
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22 -
special device for capturing HD
By adanchev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 43Last Post: 7th Dec 2008, 12:47 -
Having problem(s) with my Capturing device
By Adoll in forum Capturing and VCRReplies: 0Last Post: 5th Apr 2008, 12:58 -
What device should I use for capturing?
By Heyjoojoo in forum Capturing and VCRReplies: 4Last Post: 24th Sep 2007, 17:56
