I have a toshiba SD-1750, it plays Vcd's and Svcd's that i have, but when i burn a Vcd that i borrowed from my friend which works i know it does i burn it to make a copy for myself doing everythin i have seen on the forums! the copy would not work! I know my Dvd plays some Cd-Rs but other will not work at time im trying to figure out if putting my vcds on CD-Rw will change the outcome of my siuation but when i check the compatibility list it is not there, can anyone please help me it would be greatly appreciated!!!!
So It Shall Be Written So It Shall Be Passed Quote The Raven Nevermore
when you made a copy of the vcd, you didn't just copy the files from the vcd to your harddrive and then burn it as a data disc, did you?
easiest way (but may have some problems) is to copy the avseq01.dat file from the original vcd to your harddrive and then burn it as a vcd using nero's vcd template
DVDPlayer won´t play this video
By dexter30 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Apr 2010, 01:05 -
dvdplayer on pause
By steplock in forum DVD & Blu-ray PlayersReplies: 5Last Post: 15th Jun 2009, 15:05 -
DVDPlayer B.L.E. setting?
By wiseant in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Jan 2009, 12:52 -
SubMux ~ DVDplayer problem
By Sir Liam in forum SubtitleReplies: 3Last Post: 17th Oct 2008, 07:10 -
Will DVDplayer (OS 10.4.x) play a PAL dvd?
By rotuts in forum MacReplies: 4Last Post: 18th Jun 2007, 12:50
