Hi,
I have that problem:
I have a SVCD and I copied it to the harddisk in order to play it directly from the PC with a Software-DVD player.
So I extracted the MOVIE file with ISOBUSTER to the harddisc, but WIndows Media Player does not play it because it is a SVCD-File! So I got Power-DVD but that program only supports inserted CDs or DVDs in the CD-Rom tray.
Is there a possibility to play an extracted SVCD Movie file with a Software DVD player directly from the harddisc?
Many thanks in advance
Susan
It is possible to open files with Powerdvd, just choose filemode instead of discmode.
you don't need to do that...just copy over the file avseq01.mpg from the mpeg2 directory on the SVCD disc...you can play this directly in powerDVD/winDVDOriginally Posted by Susan27
Why i am unable to play 3D movies directly from my PC
By rollcage7 in forum Software PlayingReplies: 8Last Post: 18th Feb 2012, 07:54 -
Player that can play files burned directly from HD camcorder?
By mccake in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Dec 2011, 21:59 -
Are there any WDTV models that play flv directly without conversion?
By yoda313 in forum Newbie / General discussionsReplies: 24Last Post: 6th Jul 2010, 19:48 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
WMP doesn't play hyperlinks directly
By jemoto in forum Software PlayingReplies: 4Last Post: 16th Mar 2008, 00:37
